just when i thought i couldn't be more irritated....
Old Aug 19, 2004 | 03:11 PM
nosliw's Avatar
Default just when i thought i couldn't be more irritated....
well regardless im going to have to wait on taking the carb apart.... i accidentally buggered up the screw that hold the idle adjustment bracket to the carb....... [img]i/expressions/face-icon-small-sad.gif[/img]
well what i got hopefully is a pilot JET because that's what i asked for.
Old Aug 19, 2004 | 03:17 PM
KajunATVer's Avatar
Like I said before, the pilot JET is in the right in your picture and has the number stamped on it and DOESN'T have the spring.
Old Aug 19, 2004 | 03:39 PM
Kbass's Avatar
I take it that the pipe your talking about is the HMF slip on in you bio. The informantion I gave you about the pilot screw adjustment was from the HMF web site. You might want to go to their site. Here is their recomandation for jetting, and carb setting for their pipes.
400EX Slip On
Main Jets: 165/170 Keihin Hex Head
Modifications: Needle in the second clip position from the bottom. 3 turn out on the air fuel mixture screw
Old Aug 19, 2004 | 06:18 PM
Ozark38's Avatar
Man, that sounds really rich! I have a 40pj with the clip in the 4th slot (from the top) and only have the air/fuel mixture (pilot SCREW) out 2 turns but it runs great. I tried 2 1/4 turns and it bogged, coughed and sputtered at low RPMs. I have a PC T4 though and not a HMF but would it be THAT much different?
Old Aug 19, 2004 | 07:38 PM
  #15
400sEXridr's Avatar
the air/fuel mixture screw is right behind the idle adjustment bracket. Yes you will have to remove the bowl to get at the pilot screw.
Old Aug 19, 2004 | 08:52 PM
  #16
nosliw's Avatar
400EX Slip On
i asked a guy at hmf about them recommending something so rich, and they told me it was cause they didnt know the 04 carbs were 38mm.
i put in the 42 pilot jet, 152 main jet, no air box lid, and 2 1/2 turns out on the screw and the thing was pulling wheelies on my without even trying. she's rips. [img]i/expressions/face-icon-small-smile.gif[/img]
thanks to all you guys for puting up with me [img]i/expressions/face-icon-small-smile.gif[/img]
fordfaithful21
Dec 7, 2015 05:52 PM
Randy Marsh
3) General Discussions..
21
Nov 10, 2015 01:45 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
