K&N Filters
Old Aug 26, 2000 | 02:31 PM
norcalatver's Avatar
I read the 50 plus responses to a recent post regarding K&N filters. There is one item that no one mentioned. If you remove the air box lid you do not have to risk water and mud entering the air box. I personally run a K&N with outerwear and also run an outerwear where the lid used to be and where the snorkel used to be. I ride in sand, mud, water, and dust and have no problems. I also change my filter after EVERY ride. Make sure you buy the outerwear that is water resistant.
norcalatver rides a 1999 440EX,13:1 compression, race cam, big valves, LRD exhaust, TCS suspension,turf tamers rear, Riken radials front, Tim Farr Nerfs , renthal bars, Walsh anti vibe steering stem, titanium rear axle on the way, .
Old Aug 26, 2000 | 02:43 PM
supertraprecon's Avatar
you CHHHHHHHHHHAAAAAAAAANGE your filter after ever ride? dam that would be expensive or do you just clean it after ever ride?
Old Aug 26, 2000 | 10:06 PM
I replace the filter with a clean K&N after every ride. I have a total of four filters to rotate so the oil is always dry. By the way, the reason I replaced the stock plastic snorkel tube is water would enter through it when going through deep creeks. Since having outerwears make a custom cover that is water repellant where the intake used to be and for the airbox lid I have solved my problem
Old Aug 27, 2000 | 05:23 PM
got yea!
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
