Honda Recon Starting Problems
Old Nov 1, 2004 | 02:42 AM
hondabuster's Avatar
Default Honda Recon Starting Problems
Id try another 1/2 turn out, on the mixture screw, and see if it helps. With cold weather coming on, its bound to help.
How do you like your Kodiak?
Old Nov 1, 2004 | 03:13 AM
confusedbuyer's Avatar
i really like it, but i ride with my cousin who has a 2000 Honda 450S (NOT ES). I like his just as much, maybe more. mainly, you don't have to stop to shift on his (which can be huge in steep terrain/downshifting situations, both up and downhill). i have a little better turning radius. also, in his low gear, it just mechanically climbs (you know you have a mechanical gear and it's almost like you can feather it to move a couple of teeth at a time), whereas my auto/belt drive seems to react a little differently: in low range on downhill it locks up the tires, i gotta accelerate. just seems wierd to accelerate on a steep downhill, then yer going too fast, let off and it locks up sideways...hard to adjust to that. also, sometimes when you gas an auto/belt drive in big boulders, they seem to suddenly grab and launch, but not on a manual shift model. the belt cover snorkel came off once too, and it's kinda a poor design how it clamps on to the belt cover. my diff lock has helped me get thru some different off-camber stuff where Honda got caught with a wheel in the air. in mud, we both seem to either get stuck or get thru the same stuff. the diff lock has never helped me in the mud.
Old Jul 16, 2010 | 03:52 PM
kasman61's Avatar
Hey everyone!
I am new to the group and just purchased a 2003 Honda Recon 250 TRX Tm.
Been having idle issues similar to WarrenStripes. He said he found a hose that when he blew through it made it run better. What hose was that? I bought this used and have a feeling maybe the hoses are not routed right. I saw the carb diagram and had a question as to where hose 21 went to. I think that might be part of my problem. Any help would be appreciated. I am going on 2 weeks trying to get this running smooth. Thanks!
Old Jul 6, 2011 | 05:24 PM
HarrisonCanam800's Avatar
Default 2007 Recon ES Starting problem!!
Hey guys,my 2007 recon es has a starting issue,per say. i took it to make dealers and they cleaned out jetting and it worked perfectly for a day. then next day i go to sart it and it doesn't start! i put it on a trickle charge and that didn't work either. Any advice??????
Jun 10, 2015 12:45 AM
'86 TRX125
Jun 6, 2015 07:43 PM
j_quinn
Jan 30, 2000 12:40 AM
bgarre
Jan 23, 2000 10:17 PM
cj7
Nov 18, 1999 12:10 AM
