Kimpex Trunk (Seat)
Old Feb 13, 2006 | 03:41 PM
DirtBurgler's Avatar
Default Kimpex Trunk (Seat)
I've been looking at the Kimpex Deluxe ATV trunk for my '05 Foreman. The model I'm looking at doesn't have the rear big tail light, but instead has a cut out area made to strap down a small ice chest, storage bag or 2 1/2 gallon gas can. Runs about $230.
My 6 year old son has a Suzuki LTA50, but he likes to ride with dad on longer trail rides. My brother's softsided rear storage bag has a padded seat and is OK for adult riders, but it doesn't have anything for passengers to hold on to. I really like the built in grab handles on the Kimpex and the taller seat back. Should make kids feel pretty secure back there. Just hope they don't fall asleep.
So how does the Kimpex seat do with a full size adult rider on it? Is it wide enough for a 200 lb forty something year old ****? Do the U bolts hold it securely in place over rocky terrain?
Thanks
Old Feb 13, 2006 | 04:32 PM
RSeb's Avatar
I've had this box for about a year now. The seat is plenty big enough for a 200lb butt. Although I see plenty of people riding double using this box, please remember that adding a 200lb person plus the weight of the box and contents to the rear rack will change the handling dynamics of your quad. If you flip your bike while carrying a passenger, it could be real bad news.
I'm not saying I've never carried a passenger, I sometimes ride the kids around the yard and once I had to carry a buddy who's ATV couldn't be towed. But I think you should really think twice about carrying a passenger on a regular basis.
I usually ride without the seat attached. When stopped, it makes a great backrest with your feet on the front fenders.
Old Feb 13, 2006 | 05:21 PM
Good point on the different handling characteristics with the extra weight over the rear axle. I do wonder if extra support for the rear rack might be required given the somewhat low factory recommended carrying weight limits.
We wouldn't be doing much riding with an adult on the back, but occasionally we do find ourselves with too many people for everyone to ride solo. The Kimpex seat should be much more comfortable than two up on a foam pad sitting on the rear rack. We don't ride very fast and usually stick to the main trails or logging roads when riding with a passenger. I'm too busy enjoying the scenery to go too fast on the ATVs. I'll save the speed rush for my motorcycle.
Do I understand your comments correctly that you can remove the bottom portion of the seat independent of the backrest? If so, I think I'm liking this trunk more and more.
How about capacity in the two side storage compartments? Is there room for much or are you kind of limited because the trunk is made from plastic?
Thanks for your reply.
Old Feb 13, 2006 | 05:48 PM
RSeb's Avatar
Yep, the seat cushion is very easy to remove. There are two straps holding it on with easy to release buckles. You can also just fold it up against the backrest if you keep it on and want access to the entire stock seat. Also, you should definately remove the seat cushion when you trailor your quad. I know one guy that lost his cushion along the interstate somewhere.
I wish they had the version that has the place for the cooler or fuel tank (in place of the brake light) when I got mine. I've seen a lot of these boxes on the trails and have yet to see where anyone has actually hooked up the brake light. I saw where Canucker (in this thread) hooked it up and had problems, but he's the first person I've heard of to bother hooking it up.
It is deceiving how much space these things have. My open face helmet fits inside fine, but the full face one will not. I usually carry a tool bag across the back, a rain suit and bag with snacks, TP, flashlight, etc on one side and a cooler in the other side. You will be pleasantly surprised at how much space it has inside.
Old Feb 16, 2006 | 01:59 AM
  #15
Canucker's Avatar
Don't worry about the extra support. They put low carry limits on these to cover thier butt. You will lose control with extra weight long before damaging the rack or support frame.
Old Feb 16, 2006 | 11:03 AM
  #16
DesertFox7266's Avatar
Originally posted by: Canucker
I have the Kimpex seat. It is great.
Light lense started to melt right above the bulb. Unpluged it. I then broke the lense in an accident. When I replaced it, (lense, base, fixture and bulb) I noticed that both elements in ther bulb were both lit with just the tail lights on. Something was wrong. This should be a combination tail light and brake light. Found the bulb from Kimpex was faulty. Shorted betweeen both elements. If the old bulb was faulty also, that would explain the melting lense (both element on all the time / heat buildup). Anyway, I haven't tried a new bulb yet. Does this sound right or am I way off base.
I added some lights to my wife's motorcycle that were direct plug in replacement LED bulbs. These would be great if you can find them since they have no heat issues. I forget what that standard, dual element brake light bulb number is but they are pretty common.
Old Feb 16, 2006 | 11:16 PM
  #17
RSeb's Avatar
I just saw where Tamarack is coming out with a new box/seat. This thing looks great. If I didn't already have the Kimpex, I would definately look very hard at this box.
Check it out: Click Here
Old Feb 17, 2006 | 01:17 AM
  #18
Canucker's Avatar
Heat buildup was because both tail light and brake light was "on" all the time. Dealer who sold me the seat did the installation (included in price). Well before I took it back to blame them, I investigated myself. With a voltmeter, I found the wiring to be OK. Thought it must be the bulb. New bulb, same thing. Then it worked fine. Then just one element on and the other one just glowing. I don't know what to make of this. So I just disconnected the tail light wire and have a brake light only for now. Talk to dealer when I go there next time. They made the connections with those clip on over the wire things, that no one likes. I don't know what they are called.
Anybody have any ideas?
Old Feb 28, 2006 | 10:15 PM
  #19
Fourtrax300's Avatar
I ordered my Kimpex Deluxe trunk today. I found a listing on ebay and discovered they are a an online store that carries a lot of ATV stuff. The trunk I ordered is called the Deluxe Flexi trunk. It has a place that you can strap on a gas can or cooler. It is supposed to come with all the mounting hardware also. I expect it here on Friday. I'll post some pics when I get it.. Oh this is where I ordered from:
http://www.outdoorsmanatv.com/
badgerboy1
Sep 26, 2017 06:11 PM
Whitelx1
Oct 2, 2015 10:55 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
wrencher82
Sep 24, 2015 03:39 PM
