Recon vs Ozark in mud
Old Nov 27, 2004 | 12:32 PM
  #21
FastestBlaster's Avatar
Default Recon vs Ozark in mud
like acceleration wise. Which one would reach their top speed the fastest?
Old Dec 6, 2004 | 11:07 PM
  #22
RedReconRacer's Avatar
The 250ex would probably reach they're top speed first, because of the lower weight. My recon however will blow a 250ex away in the holeshot, but then they would pass in the overall drag, and then a 300 would win overall. As for the mud... A recon all the way, ozarks are too cheaply made in some areas, and dont have the ***** in some positions. I like my GBC Gators for mud, they work as floating paddles to work your way through, I have been in some pretty intense "goop".
Old Dec 6, 2004 | 11:33 PM
  #23
yea ill prolly end up getting the 250ex. Since its the same thing except 50lbs lighter and also i dont need the racks. (thats what the 05 kodiak 450 will be for [img]i/expressions/face-icon-small-wink.gif[/img] lol)
Old Dec 20, 2004 | 12:07 AM
  #24
pizzahutter's Avatar
I Don't Know about an Ozark but ive been in thick mud to my neck and it was still pullin strong . Only had my recon stuck once actually i was knee high in thin mud and my engine overheated.
Old Dec 20, 2004 | 12:29 AM
  #25
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
This is one of those brand loyal threads that if it had been posted in the Zuki forum, would have had a totally different response.
The Recon and the Ozark are both great bikes - definately worlds away ahead of other 250's. I've got a fair amount of seat time on both and there's no doubt that the Ozark is better in mud than the Recon. Not by much , mind you, but the Zuki has a bit more engine and a little more ground clearence - big factors is wallowing your way through a mud hole. Put more agressive tires on a Recon or a more experienced rider and yes, it will be better in mud than a stock Ozark. But then again, you could add those same tires to the 'Zark.
The bottom line is that both are great quads, I just started counting up all these 'Recon is better' posts and had to throw in a counterpoint.
Jaybee
Old Dec 20, 2004 | 07:06 PM
  #26
MUDDY4LIFE's Avatar
BOTH,
of these quads will be pretty EQUAL in the mud.The biggest differance you'll notice is that the drum brakes on the Recon WILL leak in MUD/DEBREE after awhile and be a big maintenance issue for you.
The Ozark is better suited for this because it has DISK brakes and does not have a drum to hold water/debree.
clscott84
Sep 21, 2015 10:16 AM
that1redhead
Sep 8, 2015 11:47 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Hondamx751
Aug 13, 2015 01:06 AM
traumajunkie
Jul 5, 2015 03:03 PM
