Hot Cam ?
Old Dec 24, 2004 | 03:41 PM
NCguy84's Avatar
Default Hot Cam ?
I will soon be purchasing a hot cam but i am still not sure which one to get. I am kinda leaning towards the stage 1 bc i will not be changing the piston just yet. Which one would you suggest? Also, since i am not changing the piston yet will i notice a diff in power with the new cam? Thanks.
Old Dec 24, 2004 | 03:52 PM
URCRAZY's Avatar
Default Hot Cam ?
I noticed a big difference with the stage one I had installed. I went with the 16 tooth front cause of the front end wanting to come up all the time, but I think I will go back to the 15 cause it seems it looses power and speed on the upper end with the 16.
Old Dec 24, 2004 | 11:51 PM
NCguy84's Avatar
Default Hot Cam ?
Thanks for your reply, did you just install the cam or did you put in a piston too? Does anyone else have any thoughts on this? Thanks.
Old Dec 25, 2004 | 05:47 AM
URCRAZY's Avatar
Default Hot Cam ?
I had my motor in at a Honda shop for a replace ment part that was under warantee (sp) and they looked at the piston and said it had some scuffs, so I had the bore it over .20 and put a regular piston in. NOt sure what the Compression is though. Then had the cam put in when I had the motor taken apart again for some shifting problems.
Old Dec 25, 2004 | 11:06 AM
NCguy84's Avatar
Default Hot Cam ?
Thanks for the reply. Anyone else?
Old Dec 25, 2004 | 04:26 PM
cals400ex's Avatar
Default Hot Cam ?
i would think a stage 1 would suit your riding style better but the x-6 likes the highest rpm possible.
Old Dec 25, 2004 | 04:29 PM
NCguy84's Avatar
Default Hot Cam ?
Thanks, will the stage 1 work okay with the stock piston? And do you believe that there will be a noticable increase in power?
Old Dec 25, 2004 | 04:32 PM
NCguy84's Avatar
Default Hot Cam ?
Well with that being said, will a stage 2 work with the stock piston? I know i will lose some bottom, but will it work? I am planning on getting a 11:1 piston some time real soon, but money is kinda limited right now bc of Christmas. So would it be okay for me to get the stage 2 for now that way i wont have to replace it when i get my high comp piston?
Old Dec 25, 2004 | 05:31 PM
NCguy84's Avatar
Default Hot Cam ?
Anyone?
Old Dec 26, 2004 | 11:41 AM
NCguy84's Avatar
Default Hot Cam ?
Is there anyone out there running a stage 2 hot cam in there stock 400ex? How does it run? Was there a huge loss in bottom end power? Thanks.
