FCR Carb For Christmas But!?
Old Dec 30, 2004 | 08:00 PM
MidLifeRider's Avatar
Default FCR Carb For Christmas But!?
Air box lid is off. No idea on the elevation, just guessing less than 1,000 feet
Old Dec 30, 2004 | 09:48 PM
TractorPacker's Avatar
Do you have a balloon?
Originally posted by: bulldogz400
I don't think it's lean, but on the contrary, rich. I had the same problem when I put an FCR 40 on my Z440, and it turned out that the needle was the cause of the whole problem. What clip is the needle on right now (from the bottom, or tapered side)?
I doubt the Zip-ty screw will do anything at all. I have one, and while it does make things easier, you won't see any change by buying this part.
I want you whole jetting specs...so far I've got- 180 main, 52 pilot (which sounds too fat to me), ??? on the needle and ??? on how many turns on the air/fuel screw.
Trust me, I've rejetted this carb about 500 times, on alcohol and gas, and once you get it figured out, you'll be happy you bought the carb.
BTW Tractorpacker- why did you pay $500 for the carb? FCR 40mm's can be bought for $340 from Service Honda...sounds like you got ripped....
I got an fcr 39 on ebay. Maybe it was $400, I don't remember. At either price I'm not impressed with it.
Old Dec 31, 2004 | 09:50 AM
Bulldogz you are right in line with what I have read in past postings about this same topic. Everything has been, it is too rich. I am going to get into my carb today. What is your carb set at - clip and air screw?
Old Dec 31, 2004 | 10:04 AM
TRIPLELSTROKER's Avatar
Wow, according to the computer the elevation of greenville illinois is only 500 feet!! I guess I have always assumed the further from the coast , the higher the elevation, but thats not the case!
Old Dec 31, 2004 | 10:07 AM
  #15
OregonDunePatrol's Avatar
Greenville IL is 500 feet in elevation.
Old Dec 31, 2004 | 02:43 PM
  #16
bulldogz400's Avatar
Try moving the clip on the needle up one slot (meaning closer to the non-tapered side), this will lean it out. See if that has any effect, and then we can work from there.
Tuning from the needle is very easy too, because you can get to it from the top of the carb rather than haing to take off the intake boots and twisting the carb to get to the float bowl. Should only take you 15 mins to mess with the needle...
Old Dec 31, 2004 | 11:38 PM
  #17
dunefool's Avatar
you can listen to bulldog if you want but i have the same quad and carb as you and it runs pretty strong. 190 main jet. i believe 55 slow but i will confirm soon.
Old Jan 2, 2005 | 05:25 PM
  #18
Ok I'll put it this way...YFZ's come with FCR's, and if you look, they are often around the same jetting specs as other quads with FCR's, such as Z440's and 440EX's. I'm telling you that there are not many YFZ's that flow enough air to justify a 190 main, let alone a SOHC 4 valve EX. Most piped and jetted YFZ's, which many will agree are just as fast as most Z440's and 440EX's, are right in the 170-180 main range.
Sparks, which has one of the fastest EX's I've ever seen, (465), does not even run a 190 main on their FCR equipped EX, and trust me, that is no ordinary 465.
Not trying to start an argument, it's just that I have delt with this carb so many times, tuning on the dyno, etc, that I have a very hard time believing that a 190 main and 55 pilot will not be extremely rich.
JMHO
Old Jan 2, 2005 | 09:23 PM
  #19
cals400ex's Avatar
i am with bulldog. the squirt from the accel. pump on the fcr 39 and 41's is too long for these bikes from what i have experienced. i decreased the squirt and got better results. i have a fcr 40 that the squirt is much less and seems to be fine.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
