TAG T2 handle bars what do you guys think
Old Dec 29, 2004 | 01:14 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default TAG T2 handle bars what do you guys think
The replacement Honda stem for the 400EX was $70. You can either replace bent stems or bent bars, take your pick. Actually, I think it is easier to replace a stem than pulling all the levers off the bars, and replacing the grips, etc.
KID-I got the T2 "kit", which includes the bars and mount. I really much prefer the lower bar position compared to stock, but I am not real tall and I don't have long monkey arms. If you want to keep the stock position, then go with the TAG X-5 bars, and keep the stock mounts.
Old Dec 29, 2004 | 01:27 AM
450rKiD's Avatar
recon ranger how far are the bars up with the mount do you have a picture you can show me so i can see it with them on a quad cuz im not that tall either. Also will just the TAG T2 bars with out the kit be good. u said they were lower but how much lower? And also would i be happy with the "kit" out on the trails?
thanks 450rkid
Old Dec 29, 2004 | 10:03 AM
Red Rider
The T2's are "bulge" bars, and cannot be used with the stock mounts! You must get the kit, which has the larger mounts. The kit is nice, because it comes with a plate for mounting the key and those little lights.
The bar position is about 1" lower than stock (I'm guessing). I really like it, because it keeps you lower, for more stability in high speed turns (my 450 is my desert cross-country bike).
Old Dec 29, 2004 | 10:51 AM
450rKiD's Avatar
Recon ranger what if i dont want the bars that low can i raise them up higher? Or wut bend would get me at a medium position not to high and not to low?
Thanks 450rkid
Old Dec 29, 2004 | 03:36 PM
  #15
450rKiD's Avatar
Old Dec 29, 2004 | 03:38 PM
  #16
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Originally posted by: Hippyhunter
STRONG HANDLE BARS = BENT STEM
very true
Old Dec 29, 2004 | 03:53 PM
  #17
RoughRider01's Avatar
If your taller the 6ft id recommend tag t2 cr double hi bend bars with stock stem length. Like ReconRanger said, my t2 cr hi bends are alittle lower then stock.
Old Dec 29, 2004 | 06:03 PM
  #18
450rKiD's Avatar
roughrider01 how do the bars feel that there lower than stock position? and can i get bars that are medium high so there not to high and not to low?
~450rkid
Old Dec 30, 2004 | 01:58 AM
  #19
Rcpilot's Avatar
Im in the same boat I want a set of bars that are close to the stock hight or a little lower dose any know what the stock bar hight and pul Back is ??
Thanks Tim
Old Dec 30, 2004 | 09:41 AM
  #20
Red Rider
One thing a lower bar position will do is make the bike a little harder to wheelie. Since the 450 wheelies very easily anyway, I consider this to be a positive thing! Lower bars make hill climbing easier, because your weight is lower on the front of the machine. But, the opposite is true for very steep descents, where you may feel like your weight is to far forward, and you can't get back far enough on the machine.
