400ex rear shock
Old Sep 12, 2000 | 10:51 PM
jcv400ex's Avatar
For the type of riding i do ( mainly trails) I dont jump anything higher that 6 feet and don't really plan on it either. I'm 6' 260 lbs. I think this is half my problem but my front shocks are just fine. I've been screwing around with the rear though. I just can't get it right. Now i have the preload nut maxed out, and i have the dampening screw 2 turns from the whole way in. the shock won't bottom now, but i have a pretty firm and harsh ride on the slow bumps. The rear end likes to hop around on dirt roads too. SHould i consider an aftermarket unit? Revalving if possible? A stiffer shock?
Old Sep 12, 2000 | 11:55 PM
86atc250r's Avatar
Consider having your stock shock valved and sprung for your weight and riding style. The 400EX from the factory is sprung & valved for a 180lbs rider. You will be much happier with a custom setup. This shouldn't cost all that much. On the high end of the scale would be $450 for a TCS SCS setup.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
