TRX 300 question
Old Feb 9, 2005 | 12:47 PM
theref's Avatar
Default TRX 300 question
I have a 93 TRX 300 4x4 and am wondering if anyone can tell me what the " Play (increase / decrease ) " that is just above and to the right of the oil filler hole is for? What does this adjust? Also how do you adjust the valves on this bike?
Old Feb 9, 2005 | 02:21 PM
camp's Avatar
the play and increase/decrease is what adjusts your clucthces wich i wouldnt touch unless the absoulutly need to be adjusted to adjust the valves you need to remove the gas tank and there are to covers at the top remove them the valve are right but youer gonna need a special tool go to the dealer
Old Feb 9, 2005 | 08:46 PM
Gimpster's Avatar
The nut is the clutch adjustment. To check it, hold the bolt in the center of the nut with a screwdriver, using a 14mm wrench, loosen the nut, turn the center screw counter-clockwise until a slight resistance is felt, then turn the screw clockwise 1/4 turn and tughten the jam nut while holding the center screw with the screwdriver.
To adjust the valves, remove the tank, remove the tappet covers, turn the engine to TDC. ( If the exhaust rocker has tention on it, rotate the engine 180 degrees, to TDC again ) valve clearance should .006 in.
----- Gimpster -----
Old Feb 10, 2005 | 09:01 AM
dzzy's Avatar
I think in that last part Gimpster means rotate the crankshaft another 360 degrees, or 180 camshaft degrees. I've found the easiest way to find TDC compression (where you want the engine to be when you adjust valves), is to peck the starter button and verify which direction the engine spins. Turn the engine over slowly that direction and watch the intake rocker or valve open, and then close the intake valve. The very next TDC is compression stroke.
Old Feb 11, 2005 | 10:38 PM
Gimpster's Avatar
My error, I was typing to fast, I meant 360 degrees
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
