Rincon Transmission Slippage
Old Mar 5, 2005 | 07:43 PM
rancher2000's Avatar
Default Rincon Transmission Slippage
O.K. I know that the Rincon has to be warmed up for at least 10 min.before the trany starts working proberly.Thats the way it worked for
the first 1800 miles.Now no matter how long its running it slips.Does honda have a bulletin out on this or does anyone have a idea whats going on?
Thanks for any help.
Old Mar 6, 2005 | 03:49 AM
rooster's Avatar
Check your oil level, if it is low it will slip. Make sure you check it using the method they give you in the owner's manual. That is very important for getting an accurate reading. rooster
Old Mar 6, 2005 | 09:18 AM
rezboy's Avatar
Check your oil, it happened once with mine. I took it to the dealer and that was the cause. It requires a certain amount of oil to run efficiently because the engine and the tranny share the same oil.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
