99 Recon Carb Problem - Please Help
Old Mar 5, 2005 | 08:13 PM
cpayne's Avatar
Default 99 Recon Carb Problem - Please Help
I purchased a 1999 Recon the other day as a beginner atv for my wife. It has been sitting for about 4 years and would not crank. I started by changing the oil and gas. After that it would only run on starter fluid. I then pulled the carb out and took it apart and gave it a pretty good cleaning (lot of junk in there). I have put everything back together and it runs great if the choke is on - but as soon as I push the choke down it dies. If I give it some gas while pushing the choke down it runs but hesitates - when I let go of the gas it dies. Maybe something is not set back correctly???
Please help any suggestions will be greatly appreciated.
Thanks
Charles
Old Mar 5, 2005 | 09:34 PM
hondabuster's Avatar
Most likely the pilot jet is still plugged. The hole thru the middle of the jet, is extremely small, and after its been sitting awhile, will probably need a small wire run thru it, to dislodge the crud. Check by looking thru the jet...if its clean, youlll see light thru it, like looking thru a straw.
The idle speed, could also be set too low, and/ or the mixture screw is too lean. Start with 2 turns out from lightly seated, on the mixture screw, and fine tune from there.
Welcome to the forums.
Old Mar 5, 2005 | 11:47 PM
LittleBill's Avatar
cpayne try and do some wide open runs, that usually will clear the bike out, if it doesn't, try a whole can of carb cleaner, if that doesn't work, pull out the air compressor
Jun 10, 2015 12:45 AM
'86 TRX125
Jun 6, 2015 07:43 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
