02 rancher es shift problem no codes new batt.
Old Mar 9, 2005 | 01:04 AM
trennis1's Avatar
Default 02 rancher es shift problem no codes new batt.
I have a 02 rancher es and im having problems with the electric shift. I replaced the battery and it seems to help but now it seems if i rev it to high or run it too fast it quits trying to shift. I turned the key off and back on and it works sometimes but sometimes i have to manuually shift it to neutral then it works again. Nothing is flashing or blank. The instruments are working fine. Before the new battery it made shifting sounds but wouldn't shift down except manually but the new battery seems to fix that mostly.
Old Mar 9, 2005 | 09:29 AM
framer's Avatar
Mine did exactly the same thing,take the connectors apart and give them a cleaning.Then put some new dielectric grease in the connectors and give that a try.
Framer
Old Mar 9, 2005 | 12:03 PM
trennis1's Avatar
What connectors or where are they.
Old Mar 9, 2005 | 02:29 PM
framer's Avatar
The connectors should be the ones above your right tire on the frame,the ecm is located there .Also check the ones mounted on the front of the frame.The first connector on the left looking at the front of the bike is the one that controls the shift motor.Hopefully this will help ya.
Framer
Old Mar 13, 2005 | 12:04 AM
trennis1's Avatar
The connectors look like new didnt seem to fix it
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
sara durrant
Jul 6, 2015 05:32 PM
