250R axle carrier, 400ex?
Hey I got a question for all you Honda guys...and gals.
My buddy recently bought a 87 250R. We tore it down only to discover the axle carrier is smashed, cracked, bent, twisted, and pretty much everything else. Moneys tight right now but he can get ahold of a used 400ex carrier for cheep, will this work?
Thanks
Shav -
Thanks
Shav -
No one? Common guys. And does anyone know about the bearings in the swingarm? I took them out of his 250R and am going to be replacing them soon. My question is should the bore be straight through when there is no bearings, bushings or dust caps installed? The reason I ask is because there looks to be two peices of metal, almost like circlips in each side that I can't tell if they are part of the swingarm, or are just peices seized in.
If you look at the drawing item #26 is a needle roller bearing containned in its own owter race shell.
I have built both 400ex and 250 r swing arms they both use this set up but the kits are different for the two bikes. as the ex mounts through the engine and the R does not.
http://216.37.204.203/Honda_OEM/Hond...pe=13&A=3&B=30
I looked up the 88 250r, not sure which year yopurs was ?
It's a 87. The 88's had different swingarms on them. On the 87's there are two mounting tabs, left and right, each with it's own bushings and bearings. On the 88 there was just one long mount that held a large bushing with bearings on each side. Take a look at the different years, youll see what I mean. There was bearings that came out of this swingarm, but from the pic it dosn't show it the same way I took it apart. Maybe the owner before had it messed up or somthing.
