LT80 mod kits?
LT80 mod kits?
Hello to all,
I'm wondering if anyone is familiar with a LT80 mod kit I found online?
"CT cylinder porting, head mod, carb mod, reed cage mod, air box lid mod, front and rear clutch mod, CT pipe/silencer, piston kit, and top-end gasket set." I ship them my parts. The claim is an increase from 4hp to 9hp.
Thanks,
Thanks,
It's basically my stage 2 kit with a pipe. I'm sure his HP numbers are close. Mine are close to the same. My National motor will make 11 with a stock pipe 14+ with his pipe.
He bores the carb and drills the airbox lid. He bores the cylinder and installs a crappy Wiseco piston.
I don't bore the carb. I add a vent hole so it doesn't bog in corners once rpm's are increased.
What did I do for you?
