Rebuilding 300EX Engine
Old Mar 17, 2005 | 07:16 PM
bigjohnjeeper's Avatar
Default Rebuilding 300EX Engine
First post here, hi I'm John.
My son rides a '96 Honda 300EX. It's a good quad for him and it still runs good. It is burning oil now though and is getting worse of course. Doesn't make any internal noises and still shifts fine, so I'm thinking I'll just do a top end rebuild to make it last a while until we can upgrade to a newer quad. We found a Wiseco kit with piston, pin, rings, clips and gaskets for about $100. I know a local guy who has his own motorcycle/atv shop who can bore the cylinder and diamond hone it. I'll hand lap the valves as long as they aren't too worn. I plan to clean out the carb while I'm at it.
I've rebuilt truck and car engines, but never a quad or bike engine, so I'm looking for some input on the details and any quirks about this model. Anything I should check while I'm in there? Not looking to hot rod it, just stop the smoking and make it last.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 17, 2005 | 07:21 PM
schonertkyle's Avatar
Hello John, welcome to the forums. That sounds like it would work pretty good. Make sure you port and polish the head while your at it. But get some other guys oppinoins on here first. Im not great with the motor.
Old Mar 17, 2005 | 08:39 PM
schonertkyle,
Thanks for the welcome. That's a good idea on the port and polish. I haven't done that since my mud racing days. [img]i/expressions/face-icon-small-happy.gif[/img]
Anyone have anything else?
Old Mar 17, 2005 | 08:55 PM
Semms40oz's Avatar
Check the cam chain... make sure its in tolerance. Throwing one of these costs $$$$... also check the valve guides and make sure thats not how oil is getting burned. Check the cam and rockers also. If everything checks out it'll last another 9+ years. If you decide to port/polish realize you won't see much gain unless you have a decent pipe and have the airbox opened up with jetting to match.
Old Mar 18, 2005 | 12:27 AM
maddmudder13's Avatar
i own a 86 trx 250 and in the oweners manual it says NOT to lap the valves? is there something different with my engine? it says it has a special compound in them that if a lap them i will distroy the seal. im planning on rebuilding the motor soon so im just wondering
Old Mar 18, 2005 | 01:29 AM
Gimpster's Avatar
Titanium coated valves are great, until the titanium is worn off, then the valves will go away fast. On the newer engine platforms running hotter exhaust temps, it is being advised not to lap valves as it may cause premature failure of the valve face and seat. I think the engineers are rethinking the use of titanium coated valves for this reason.
Welcome to the forum John
----- Gimpster -----
Old Mar 18, 2005 | 09:32 AM
asfasasu3's Avatar
This sounds like what I had planned for my sons 300. I'll tell you what I found out. In ours, the rings were worn. (just like I would have geussed) While tearing it on down, the rod was loose on the crank, 2 of the valves were burned up pretty good. (Mickey Dunlap says this is VERY common) And the timing chain was wore out. I have put in a new rod, and a good friend of mine has a brand new 11:1 piston for a 250x that I'm going to use. (should put the 300 to about 12:1) It already has a White bro's cam and a Pro circut pipe, and been jetted. I've been waiting on the timing chain and hope its in today. Our spring break is next week and we would love to get to ride while the kids are off.
Good luck with it !!
Old Mar 18, 2005 | 12:24 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
If you have rebuilt car and truck engines, then you will have no problem with these. Especially the EX's, they are a very simple model in and out. Replacing what you stated will make it last for years and years unless simple bad luck accurs.
Also, I would rebuild it to, but burning a little oil isn't going to hurt anything unless it is pooring it out. I only say this incase you told him to stop riding it or something until it is fixed.
Old Mar 18, 2005 | 06:30 PM
Thanks for all the input and welcomes. Hopefully I won't find too much wear on other parts while I'm in there. I guess I should not lap the valves and just check them for wear. My son is still riding it, but it smokes pretty strong off and on. The end of the pipe is a little oily. I have seen worse though.[img]i/expressions/face-icon-small-happy.gif[/img]
Any special tools I'll need?
Yeah, I won't tear it down until after we do some riding over spring break. I wanted to take him to the Badlands this Sunday, but work schedule doesn't allow it.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Mar 19, 2005 | 01:51 AM
TractorPacker's Avatar
Do you have a balloon?
I have taken a 300ex apart, and put it back together wrong. The cam chain tensioner is automatic. When you take it off the cylinder it travels to its maximum adjustment. I did not know that, it needs backed off(and held) while installed. If you have the service manual, this is well covered. If you don't have a book you might want to throw the $20 at it.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
