trx250x stalls when warm
Old Apr 5, 2005 | 10:41 PM
  #21
87250xman's Avatar
Default trx250x stalls when warm
It starts up with the old cdi.
Old Apr 6, 2005 | 03:41 PM
  #22
hondabuster's Avatar
Still stalling when warmed up? Did the reverse light issue go away?Did the plug in for the cdi seem ok, not loose or coroded?
Old Apr 6, 2005 | 10:20 PM
  #23
87250xman's Avatar
When I put the old cdi in it in starts up but still stalls when warm.
Old Apr 7, 2005 | 02:43 PM
  #24
Then youre back to doing more troubleshooting.
Do you have a ohmmeter? Did you check the resistance of the stator coils? Did you recheck them when the motor stalled?
It could also be the wiring harness, like the other guys have said. Youll need to look over the connections, and plugs, and maybe wiggle them while ohming them out, looking for intermitent connections.
Old Apr 8, 2005 | 03:15 AM
  #25
dork's Avatar
the 250x and 300ex cdi's aren't compatible. the 300ex is a DC unit, and the wires in the harness are different on them. your problem does sound like a possible stator though. the specs in the honda manual are 100-300 ohms between the black/red wire and ground for the stator. try to measure it before and after it stalls. bad stators aren't all that uncommon on the 250x's. also check the connectors at the coil, i had a wolverine act up after 5 minutes of running, it would cut out like it was starving for fuel. turned out to be the primary wire on the coil was loose and corroded, cleaned it and tweaked the connector, and it was fine.
Old Apr 8, 2005 | 09:43 PM
  #26
87250xman's Avatar
I put a OEM cdi on it and it runs fine now.
Pehter
Oct 3, 2024 11:00 PM
IMLN
Sep 28, 2015 03:32 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
