Honda Recon 250 Problem
Old Apr 4, 2005 | 10:07 AM
wicrules's Avatar
Default Honda Recon 250 Problem
I have a 2004 Honda Recon. Here's the history- rode for several hours one weekend. Following weekend would crank, run about 15 seconds and then die regardless of how much throttle... This past weekend dissasembled the carb, soaked in parts cleaner for about 30 minutes, blew out with compressed air. Also emptied gas tank, cleaned gas filter per maintenance manual and reassembled everything. Also replaced spark plug. After about 10 minutes of not cranking, it fired up and started the same crap again (and yes, I did put gas in it). I'm now at a loss. Any suggestions?
BTW, the carb has now been soaking in parts cleaner overnight....
Thanks,
wicrules
Old Apr 4, 2005 | 10:29 AM
TIC's Avatar
TIC
Float adjustment? or it does sound like the classic vent tube kinked or plugged... try running it without the gas cap on.
Old Apr 4, 2005 | 10:59 AM
wicrules's Avatar
Thanks for the thoughts... I removed the gas cap and blew through the vent hose. Doesn't seem clogged to me. As far as float adjustment, I can't imagine it being that considering the thing is less than a year old.... never know though.
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
