250EX no spark
Old Apr 19, 2005 | 02:24 PM
robthenailer's Avatar
Default 250EX no spark
My 250EX will not spark. It is cranking over. I have tested spark plug and replaced it also. No spark to plug. Anyone else had this experience? Thanks for help.
Old Apr 19, 2005 | 03:52 PM
hondabuster's Avatar
Start with the easy stuff...kill switch on?
Old Apr 19, 2005 | 04:36 PM
Checked the kill switch...even took it apart. It acts like the kill switch is on but it is not on. I did follow the green kill switch wire down to where I think it connects to the main harness, cleaned, unplugged, tested connect/unconnected. Still no spark.
Old Apr 19, 2005 | 04:53 PM
Been thru deep water? Or has it just been siting in the garage, and now it wont spark? Are you getting the nuetral light?
Old Apr 19, 2005 | 05:04 PM
not through deep water. green neutral light on. pulled in on rear hand brake also as possible source of no spark but think that safety feature only affects starter motor.
Old Apr 19, 2005 | 05:35 PM
What year is it?
How the the spark plug cap look? Is the cap, screwed tighly to the wire? If you take the cap off, and just hold the wire 1/4 inch from the head, and someone spins over the motor, do you get spark then?
Im using a service manual from a recon, but im thinking for this, the motor and ign system are the same.
Old Apr 19, 2005 | 08:25 PM
This is a 2003 250EX Sporttrax.
I don't understand this question exactly. It is a RED cap....it connects to a black wire. The cap has a bend in it where the wire joins it. The spark plug wires runs about 12-15" to a "coil" looking device with two wires on the back of it and one (ground?) wire connected to the frame mount bolt.
No spark. I took off the RED cap, and held the black wire 1/4" from the plug...nothing.
Thanks much for this help. I don't have a service manual so am struggling.
Old Apr 20, 2005 | 04:35 PM
The next steps are kind of involved. The clymers I have , says to use a peak voltage tester, or the peak voltage adapter from honda for the checks. On all the other quads I worked on, they ask for resistance readings, and not peak voltage.They also say the volt meter should have a minimum 10 M ohms of impedance.
They list the ign coil , the exciter coil,and ign pulse generator as the next three items to check.
Im not sure how you want to go...youll need the special adaptor, and probably should get the clymers book. Check out the local library, itll be in the 629.28 area of non fiction, if its not there, then youll probably have to buy one.
You could try looking over the connectors, and make sure they are corrosion free and dry, and making good contact.
Check over the fuses as well.
Old May 31, 2005 | 02:33 AM
prieber14's Avatar
my cheap, quick, uneducated guess would have to be bad wiring
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
