2003 Honda 400 EX parking break issue
Old Apr 29, 2005 | 12:59 PM
E7O's Avatar
E7O
Default 2003 Honda 400 EX parking break issue
WOW! I searched for "brakes" and came up with more posts than I bargained for!
However after reading nearly 12 pages of parking brake issues and block offs...
What if I want to keep my parking brake...how do you clean it and adjust it correctly?
Old Apr 29, 2005 | 01:36 PM
E7O's Avatar
E7O
Double post.
Old Apr 29, 2005 | 01:38 PM
Harw's Avatar
You can adjust it back at the caliper. Brake the nut loose on the arm and turn the bolt in till it stops then back it out a 1/2 turn. They never did work to well. I use black tape. Pull the front hand brake in not real tight and wrap a couple laps around the hand brake to the handle bar.
Old Apr 29, 2005 | 01:48 PM
E7O's Avatar
E7O
I guess that would work!
But seriously is it just the bolt that controls the spring lever to the left of the caliper? Just clean and tighten it?
Old Apr 29, 2005 | 07:56 PM
powerslider's Avatar
Just unbolt the lever and the 2 bolts on the caliper that hold the parking brake cam, take the cam out of the housing and clean it and the housing then apply grease to those parts. It'll work like new again....
neilbedwell
Nov 10, 2018 11:02 AM
3quadbob
Sep 18, 2016 09:46 PM
Jake55
Jun 29, 2015 06:43 AM
neilbedwell
May 31, 2015 11:11 AM
lovinhonda
Jan 25, 2000 09:17 PM
