ignition qusetion
Old May 7, 2005 | 12:00 AM
devocorky's Avatar
Default ignition qusetion
I noticed today my netural light was lit up on my 300 fourtrax. The bike had been sitting for a few days and the key was turned off. When i started it i turned the key off and the bike kept running. Is there a short in the ignition or something. Is this common?
Old May 7, 2005 | 05:32 AM
confusedbuyer's Avatar
never heard of it, but it does sound like your ignition is shot. I've got an extra ignition that fit on my '02 Honda 400 Foreman. PM me if yer interested and i'll find out more details. you can also buy a factory one from Honda but i think you're gonna find that hurts.
Old May 7, 2005 | 11:26 AM
hondabuster's Avatar
Have you got teenagers? Could they have put a jumper in there, to hot wire it? Or it could be the switch is shot, and it is hanging up, and not getting to off.
Old May 7, 2005 | 01:44 PM
devocorky's Avatar
Noone has tampered with it but mabye it is getting hung up, what can i lube that with??
Old May 8, 2005 | 12:42 AM
What year 300 is it?
Most likely the slot for the key isnt the problem, itll be the electrical contacts inside of it.
If its a two wire switch, pull the connectors going to it, and use an ohmeter to check. in one position there should be continuity between the wires and in the other position itll be an open. My guess, is your going to find continuity in both positions.
At that point you can try to repair the contacts inside, or toss it and put in a toggle switch, or buy a new key switch.
Old May 8, 2005 | 02:02 AM
quicksilver's Avatar
easy to find- if the bike doesnt kill by turning the key off, but it kills if you UNPLUG the key switch, then the problem is in the key switch. If it still stays running with the key switch unplugged, then you have a problem somewhere else.
Old May 10, 2005 | 08:21 PM
devocorky's Avatar
Now today i get on the bike and no power to start it!! I kicked it and ran it for a bit and it charged it up a bit. I am wondering if when i installed my winch the other day i connected right to the battery, both pos and neg. Would this have anything to do with it???
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
