250r runs full throttle
Old Jun 6, 2005 | 10:23 AM
  #21
8dave3's Avatar
Default 250r runs full throttle
The reeds are located in the area you are talking about.Pull the carb off then take out the bolts on the side of the cylinder.The reed cage will pull out of the cylinder.The reeds are the fiberglass or carbon fiber petals that screw to the cage.They should lay flat against the cage and check for cracks,chips or holes on them.The idle trouble your having is a symptom of bad reeds.
Old Jun 6, 2005 | 03:45 PM
  #22
Hoopie's Avatar
Ok, I will check them today and post what I find out. Thanks again
Old Jun 6, 2005 | 08:12 PM
  #23
Hoopie's Avatar
Ok I took out the Boyesen RAD and checked out the Reeds. It looks ok. There is no cracks or chips in it. I dont know what the spacing should be on it though? I took pics and put them in my photos. I need a new gasket now though because the gasket got torn taken it off.
Does it look ok? By the way how much HP is this suppose to add?
Old Jun 7, 2005 | 02:42 AM
  #24
8dave3's Avatar
Those reeds look ok.When you checked the compression,you held the throttle open and kicked the kicker until the gauge quit moving right?It is possible the carb is in bad shape.It may be an airleak,but you have made progress from the starter fluid,so Im still leaning to the carb.
Old Jun 7, 2005 | 09:42 AM
  #25
Hoopie's Avatar
No, I think I did the compression wrong. First I just did it with one kick and it register 90. I then kicked it three times and it registered 160 but i figure that was a build up of compression so it wasnt accurate. I never touched the throttle.
Also if you notice in the RAD pic one of the reeds does not lay flat against the metal. It has a 1/8 inch gap. Is this ok? the other side is flat against the metal.
Old Jun 7, 2005 | 12:35 PM
  #26
8dave3's Avatar
I didnt notice the gap.There should be no gap.You may be on to something.
Old Jun 7, 2005 | 01:09 PM
  #27
2StrOkeFReaK's Avatar
Hoopie,
You are definately on to somthing with those reeds. Replace the petals or for now try flipping them over and see if they will seal tight against the reed block. They need to be tight. When you re-install your reed cage use gasket adhesive only on one side of the gasket so you can take it apart again without destroying the gasket. Same applies to your side cover gaskets too, adhesive on cover side of gasket.
Best thing I ever did to my R's is get rid of the stock carbs. I run a 36mm pwk on both, and they run great in the woods.
Once you get it running right try using Amsoil Dominator at 50:1, I've never fouled a plug on it.
Good Luck!
Freak
Old Jun 7, 2005 | 04:48 PM
  #28
Hoopie's Avatar
What is gasket adhesive? Where do I get it?
Where can I find a replacement gasket?
Thanks
Old Jun 7, 2005 | 06:27 PM
  #29
8dave3's Avatar
I use Three Bond adhesive.You should be able to get an intake gasket anywhere that sells the reed cages.If you have trouble finding one,Ive got a few laying around and Id be happy to give you one.
Old Jun 7, 2005 | 07:42 PM
  #30
Hoopie's Avatar
I flipped the reed over and it screwed down flat against the metal. So that should be all good. I will try to get a gasket from the local honda dealer here for it and 3bond adhessive from a autoparts store?
