What is the highest compression ratio I can run?
Old Jul 2, 2005 | 11:20 AM
OutRacing's Avatar
Default What is the highest compression ratio I can run?
Hello all, I have a 400ex, It has been bored to a 440. I was wondering, it is getting close to time for a top end rebuild, what is the highest compression that I could run. I will be able to burn 110 sunoco purple race fuel. Thanks!
Old Jul 2, 2005 | 11:56 AM
Doctorturbo's Avatar
GOT BOOST!
As far as the fuel your burning; about 14 to 1. But detonation depends on a lot more than static compression.
Old Jul 3, 2005 | 02:32 AM
TractorPacker's Avatar
Do you have a balloon?
If you go over 12:1, at 89mm, the head studs become an issue. You can get a stud kit, and you'll thank yourself in the long run, if you get them. The stock studs can pull and lead to head gasket leaks or worse, pulled studs.
Scooter's Shop
Oct 9, 2015 02:09 PM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Steeldon
Sep 9, 2015 09:38 AM
