WARN 4-2-4
Old Jul 7, 2005 | 12:31 PM
MrBaldone's Avatar
Default WARN 4-2-4
Can this be shifted from 2wd to 4wd while on the fly, or do you have to be stopped. I.m considering a purchase and the atv has the warn 4-2-4. thanks
Old Jul 7, 2005 | 12:49 PM
RedGoblin's Avatar
Default WARN 4-2-4
It works better if you are moving, but off the throttle. It can be done stopped too however, but may not engage/disengage instantly.
Old Jul 7, 2005 | 01:50 PM
action450s's Avatar
Default WARN 4-2-4
You can do it any time on the fly provided the tires are not spinning. If they are your in trouble, I usually let off the gas when switching. Switching when stopped dont always work becuase the gears aren't always lined up, moving slowly makes it easier, but its no more difficult than switching the tranny when stopped (sometimes you have to rock the bike).
Old Jul 7, 2005 | 08:44 PM
snowbuster's Avatar
Default WARN 4-2-4
He means if the front and rear wheels are spinning at different speeds. You want to synchronize the gears before allowing them to mesh.
Old Jul 8, 2005 | 12:09 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default WARN 4-2-4
I engage it on the fly, but never under a heavy load. I do try to anticipate needing the 4wd, and switch it before it's an emergency.
Jeff Roper
Feb 1, 2022 11:48 AM
toonces
Oct 19, 2015 02:21 AM
panicmanic
Sep 28, 2015 12:59 PM
Erick J. Edler
Sep 20, 2015 05:51 PM
Gtsordo
Jul 22, 2015 01:27 PM
