Rancher dying, any ideas?
Old Jul 19, 2005 | 03:19 PM
Kerbbirds's Avatar
Default Rancher dying, any ideas?
Have an 02 Rancher that will just die while your riding. After it dies you can put it in nuetral and start it rigt up, may go for another hour may quit again in a couple minutes, no ryme or reason to it but always restarts good. Any Ideas?
Old Jul 19, 2005 | 04:23 PM
hondabuster's Avatar
First thing to check, would be the tank vent, and the carb vent. If either was plugged, youd get those symptoms.
Old Jul 19, 2005 | 08:20 PM
quicksilver's Avatar
hondabuster is right, carb or tank vents cause suction to build in the fuel system and stop fuel flow. also, could be a bad ignition coil, they heat up from running and the circuit opens inside, then when it dies the coil cools off since it's not running, and the circuit connects again and it will start right up.
COFatboy
May 2, 2020 12:06 AM
txpedsrt1
Feb 3, 2017 08:07 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
