Blowed Fuse problem Fourtrax 2001 350
Old Jul 25, 2005 | 11:16 AM
Fourtrax2001's Avatar
Default Burned Fuse problem Fourtrax 2001 350
Hi
My Main Fuse 30A always burned. I was driving my ATV when suddently, no power.
I have checked all my wire, and i don't see short. Maybe a defective piece ?
Fourtrax 2001
350 electric shifter
thank you
Old Jul 25, 2005 | 02:14 PM
hondabuster's Avatar
Default Blowed Fuse problem Fourtrax 2001 350
This can be an easy or a tough one to figure out.
Does it keep blowing the fuse? Does it blow the fuse with the key off, or just when on?
It most likely is a connector which is wet, or a bare wire touching the frame, or a component. There are ways to track it down, but itll take a test light. And some basic electrical knowledge.
Old Aug 5, 2005 | 09:12 PM
I think i have a clue.
When i disconnect the rectifier/regulator, my ATV is starting very well and my fuse doesn't blowed anymore.
When i reconenct the piece, my fuse blowed.
How can I test the rectifier/regulator. I want to be sure that it's the right defective peice before replace them.
Thanks.
Old Aug 5, 2005 | 09:29 PM
4504x4's Avatar
Dude i totally have that same problem, but my starter button won't work, headlights and display won't come on either, and the fuse doesn't keep blowing.
skinnyr6
Aug 25, 2023 02:18 AM
Ramman1
Jun 16, 2016 09:07 PM
honda71
Jul 8, 2015 02:13 AM
