Dyno jet kit?
Old Jul 27, 2005 | 03:45 PM
Thunder53's Avatar
Default Dyno jet kit?
what is a dyno jet kit and what does it do?
Old Jul 27, 2005 | 04:03 PM
fillae's Avatar
Well first, a jet is a like a nozzle that controls the flow of gas to a carburetor. A jet kit is a set of jets of different sizes that allow you to set up your carburetor to run efficiently under different conditions. For example, at higher altitudes there is less oxygen, therefore your carb needs less fuel, so you need a smaller jet to create a LEAN condition. At lower altitudes there is more oxygen therefore you need more fuel to create a RICH condition. If you are running too LEAN, your engine will run hot (not a good thing). If you are running too RICH, your engine will seem to bog down. Air temperature can also affect this. When you bought your ATV, it was probably jetted for the altitude you live at. Dyno is a specific manufacturer of jet kits.
Old Jul 27, 2005 | 04:17 PM
Thunder53's Avatar
thank you for the information
Old Jul 28, 2005 | 09:56 PM
zippy's Avatar
try www.jetsrus.com they sell jets that dont require adapters like dynojets. Dyno jets numbers dont match anyone elses either. I have heard some nice things about www.jetsrus.com JMO
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Cantbuytime
Aug 17, 2015 06:33 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
BlackHawk
Jun 9, 2001 04:13 PM
