WARNING!!!
All of our Hondas were that way and had to adjust the idle. The sportrax is easy to get to. Sitting on the bike it is on the right side of the carb right dab in the center. As you turn the slotted screw in it raises the slide and the idle speed. Be careful not to adjust it too high or it will make the transmission hard to get out of reverse. The clutch wont release quiet as good if the idle is too high.
#17
You really couldn't just order the light itself. The 250ex motor probably doesn't have any temp sensors on it that you would need, and it's definitely nowhere in the harness to plug the temp light in.
Jeff Roper
Feb 1, 2022 11:48 AM
