rear end oil for 86 250 utility??
Use the Honda 90 weight gear oil. There should be a fitting on top of the differential to fill it up and a screw on the side that you remove to know when you have filled it the correct amount(oil will start to come out the screw hole).
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
