Is Honda Making a 650 sports quad?
#35
#36
You have proven me wrong on the Brute and the King Quad, but you are wrong about the Outlander. A Brute Force stock goes 70 mph according to Dirt Wheels on the GPS, your Rappy with a pipe goes 73 and I bet a stock is more around 71 or so. Even though a Raptor in stock trim will beat a Brute that is also stock. The Outlander easily crushes a Brute from start to finish and has been GPS at 76. And it will also beat a Raptor 660 in stock form. The 800 has 140 more cc's than the raptor and is light weight for a utility. "atv rocks" and my self think a Outlander will win. Keep in mind I'm talking stock machines, I know it would not take much modification for the Rappy to beat the BRP 800.
#37
I dont know what to say, i dont guess i can get it through your head. You obviously have a big problem with the raptor because you state two utes that are supposedly faster, and i prove you wrong. Therefore you come back with "the outlander is faster." Im not buying it, you know why? Because i know the truth, if the bomb was faster i would've bought one, and so would alot more people.
Someone please chime on in and set the records straight.
I think you are just sore from getting beat by so many raptors on your little 400. But thats ok in stock trim the rappy is faster [img]i/expressions/face-icon-small-wink.gif[/img] .......faster than any stock ute.
#39
Bigger tires= more topend, there is no way in the world a 600 ib. utility will beat a stock raptor. Even if it could, put both on a track and then see what happens. Also, If you add a pipe to any atv, it will not make your top speed higher. The only way you can get a higher topspeed is if you have larger tires, new rev limiter, or gearing changes. An engine can only spin a limited rpm's with the stock cdi, so unless there are gearing changes, new rev box with a higher rev limit, larger tires, your top speed will not change.
