Important 400EX Mods for MX?
Old Nov 9, 2000 | 10:49 PM
  #21
Blazin_Banshee's Avatar
You might want to check out rickystator for the arm if I remember right he had some really good looking ones cheaper than most. I have the TCS shocks on my banshee and they are great after you get them dialed in. Just make sure you get the shocks and arms at the same time or you'll pay extra money to have the shocks revalved after you get the arms. Having the rear redone worked great for me, but not sure on a 400. You might want to call shoc connection to get some ideas since all the do is suspension. Also K and K sells both TCS and PEP they can give you a good idea of what they think. When I bought my TCS shocks from Graydon they told me they were as good as the PEP ZPS for less money.
Hope I've helped a little
David Chapman
Old Nov 9, 2000 | 11:17 PM
  #22
jeepin's Avatar
I have JD performance a-arms on my 250r.The fit and finish is first rate and they offer more camber than leager's.A freind of mine had leagers on his 250r and after I got mine he switched and said he liked the JD's better.
As for shocks I have white bro's white powers.There not as well know as works but they are supposed to be better according to the shop I got them at who sells both. I got mine used all 3 with extra springs and piggy back adjustable res's for 700 bucks.Which really isn't that bad for all 3.
I also got a durablue eliminator axle 2+2 adjustable width and I really like it it helps alot.
You will need some mx tires alot of people say turf tamers.I got holeshot mx's and I love them.They get flats very easily though.They have awesome traction and are very predictable. I run about 3 psi in them and they work great.
hope this helps
86 trx250r wiseco .020 piston,boyesen reeds,porting by p.m.s,FMF gold series fatty pipe,power core 2 silencer,dg alloy series nerfs,JD performance +2 A-arms,durablue eliminator 2+2 adjustable width axle,durablue posi loc axle nut,white bro's white power shocks with adjustable res's all the way around,LSR bearing carrier,Fastline braided steel brake lines,nac's casesaver,uni filter,braking brake pads,18/11/8 holeshot mx's on ITP .190 wheels,21/7/10 holeshots on ITP wide off-set .190's
www.angelfire.com/me3/fmf86trx250r
www.angelfire.com/me4/muddyR/pics
Old Nov 12, 2000 | 01:37 AM
  #23
wcy2k400ex's Avatar
Do either two places have websites? Also, does anyone know any other good ideas? I am trying to go for the best "bang for the buck" setup. I don't want to spend a great amount on this stuff, but I don't want to buy cheap crap.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Sep 23, 2015 06:23 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
