400ex problem
Old Jan 3, 2006 | 06:50 PM
FrostyLemon's Avatar
Default 400ex problem
today i pulled it appart and the beaearings are toast one bearing has the outer race stuck in the bearing carrior any ideas on how to get it out
Old Jan 3, 2006 | 09:00 PM
slomoe's Avatar
this happened to me last time we had to cut it out with a dremmel tool be careful not to ruin the carrier.
Old Jan 4, 2006 | 09:28 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
You can also try sticking some sort of pic thru the oppsite side of the bearing carrier, and see if you can beat it out by hammering on one in of the pic, and the other end against the outer race of the bearing.
Old Jan 4, 2006 | 01:23 PM
ryanwolfe911's Avatar
The easiest way to get those races out is to knock out allof the bearing, leaving just the race left in the carrier, take a MIG welder, and run a bead all the way around the race where the ball bearings ride. The heat from the welder changes the molecular properties of the metal, and fatigues it, often to the point that the race will just fall out of the carrier. It works great. I am a car mechanic, and I do it all the time to remove automotive wheel bearings, so I don't have to use a press to get them out.
Old Jan 4, 2006 | 05:29 PM
  #15
Anto's Avatar
i am getting a new quad but don't know what too get between a 400ex or 450r people have told me that you need to rebuild the engine after a awhile on a 450 is that true? i want to get the 450 but i don't want to keep going to a mechanic and i also need the quad for at least 7 years is that too much to ask from a 450?
Old Jan 4, 2006 | 05:40 PM
  #16
motox26's Avatar
Shed Knocker Rider
Harley Punk!
7 years is a long time for any quad that is ridden frequently. You might want to look into the EX.
Old Jan 4, 2006 | 05:45 PM
  #17
Anto's Avatar
if i get a 400ex and put a bore kit or something in the future do you think i will having a hard time with maintenance?
Old Jan 4, 2006 | 11:59 PM
  #18
dude wuts with the hijackin
i decidend im gonna try and make my own bearring carrier does any 1 no where i can get dementions
Old Jan 5, 2006 | 11:00 AM
  #19
Hope you have a CNC lathe and some sort of Auto-CAD program, or you're out of luck. Dude you can buy them brand new on EBAy for $125. Dont waste your time.
Old Jan 5, 2006 | 11:18 AM
  #20
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I agree, unless he is a really good machinist with the right equipment.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
