CRF450X Transmission Failures???
Old Jan 16, 2006 | 10:56 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default CRF450X Transmission Failures???
Seeing that the 06 450R has basically the same engine/trans as the X, you 06 owners might want to consider this.........
There have been a few 450X transmission lock ups. There is some discussion that if the oil level in the trans is even slightly low, it can cause a transmission failure!
Word is that you need to run an extra 200cc's (above the weep hole) of oil in
your X transmission! The gears ride above the oil line and are not totally
submerged in oil, so they are lubed only by the oil they carry up with them. This is
designed to cause the least amount of drag, but can cause a disaster if you are
even slightly low on oil. The shaft is also lubed by splashing, so a little
extra oil doesn't hurt here either.
Old Jan 17, 2006 | 09:37 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I've heard of some of the CRF's making a "winding" noise and adding extra oil cures this without harming the engine what so ever.
Old Jan 17, 2006 | 03:25 PM
ATVtech1's Avatar
I've seen you on Thumpertalk a few times, I assume that's where you got the info.
From what I gather, the problem has mostly been from people dual sporting their X's and running long, straight, smooth surfaces, where the engine doesn't "bounce around" and provide oil to the upper end of the transmission. I guess some quad riders ride like this, but most of them ride rough terrain. The problem probably won't arise as much on the quads, but I would definitely add the extra oil just for insurance.
Like was said on the TT forum. Honda should issue a bulletin telling people to run the extra bit of oil.
Old Jan 17, 2006 | 04:09 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
This is where my info is coming from as well. There's a lot of good info over there.
Old Jan 18, 2006 | 10:51 AM
Red Rider
Mine has a slight whine as I let out the clutch on a DOWNSHIFT. Sounds like it could be a bearing, but it might just be the plates coming back together. I had been running 85W Maxima MTL in the transmission, which is supposed to be the same as about 30W engine oil, but MTL seemed awful thick! I called Maxima, and they suggested I switch to their Extra, ester synthetic oil in the trans. This was an easy one, because Extra is what I run in the engine side.
I have the extended warranty, so if its a bearing it won't be a disaster financially.
Old Jan 18, 2006 | 05:23 PM
URCRAZY's Avatar
A guy here where I live blew his in like 3 months. He only used his for recreation. Blew a hole in the case also.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
