who has the BADDEST 400EX?
#31
Originally posted by: URCRAZY
I dont think I have the baddest, but I do think I have a nice looking 400.
Completely Redone in 2003
Motor bored over .20
Hot Cam Stage 1
Hinson Complete Clutch Set Up
Curtis Sparks X-6 Exhaust
39 FCR Carb
Alum, air/batterybox
New blue Maier plastic
K&K Seat and sticker kit
Lonestar +4 axle
Lonestar e-brake cover
Lonestar Rear Disc axle nut hub
450R Rear Shock
Roll Design Kick up Foot pegs
New Rubber gourments OEM
Alum Pingry Oil Tank Res.
Elka Triple Rate Front Shocks
JD Performance +2 A-Arms
PRM Front Baja Bumper
Maxxis IRazar Tires Front and Rear
ITP Rear wheels
Douglas Front wheels
Trail Tech Big bars and clamp
Magura Hyd Clutch
Frame and Sub Frame sand blasted, and Powdercoated Cardinal Red
Stainless Steel Polished bolt kit for almost all bolt on quad
I believe this is all. My next step is to do a motor swap with something bigger.
Hot Cam Stage 1
39 FCR Carb
Lonestar +4 axle
450R Rear Shock
ITP Rear wheels
Magura Hyd Clutch
#32
Originally posted by: 400EXRider67
my bike is nowhere near the baddest or fastest but seeing as how i stepped up from a 300ex its got plenty of power for me. the works suspension is nice and the 440 kit makes it more powerful then stock. im actually looking into a stage 2 cam for it. not for sure though.
Reason I said who and how is because there are certain ways to do it that make a big difference in how the engine will perform, and all the other stuff from cams to porting etc will be effected by the how, and the end result of how well it all works together will too.
