rancher at wont shift
Old Feb 3, 2006 | 01:14 AM
hines57's Avatar
Default rancher at wont shift
I have a 04 rancher at that wont shift out of first gear. The esp blinks 6 times and doesnt work at all. I have looked at other post and they say that code is a fail safe relay circuit. I have another rancher that I swapped parts with and now they are both doing it. I have swapped the tcm and a sensor on the side if the transmission it has three wires going to it thanks
Old Feb 3, 2006 | 03:19 PM
444XCrecon's Avatar
I had the exact same probem with my recon, now i wish i would have got the recon with a footshifter,i took my recon to the atv machanic he said it almost always happens with the esp models like the recons,ranchers and foremans he said the angle sensor went bad.
Old Feb 3, 2006 | 07:40 PM
hines57's Avatar
I dont think it is the angle sensor. I called my local honda dealer and they said it was the ecm which is on a recall that has not been performed yet. i would like to reset the computer, they said that it would work for a while. thanks
Old Feb 3, 2006 | 10:20 PM
slough's Avatar
hey there hines. i have the same bike same year . and was haveing the same problem like 3weeks ago. let me ask u a ? when the dash is blinking does it blink 3 times then stops fora sec and then blinks 3 times agan . if so its ur throttle sensor, its the black sesor onthe left sid of the carb and it has a wire pack connected to it how is discoverd it was when i took it off to adjust my vavles on day i must have put it on wrong and it casued that problem . after talking with a few of the guys in the forum they gave me the idea on what it was and thats what i was . so id check that out cause it might be bad .
Old Feb 3, 2006 | 11:07 PM
hines57's Avatar
Thanks for the info but my esp light blinks 6 times in a row then pauses and starts blinking again. I quess I will wait to see what the dealer says when I take it in for the recall. Thanks again
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
Elkaholic
Sep 6, 2015 02:44 PM
