help my rancher from getting stuck in sandy creeks
#21
west Virginia is called the mountain state. in case you didn't know Ohio is right next to this state. if it is wet out may be on a steep hill you cant hit hard and you might break traction, but give me a few tries ill find a way up.
in case you didn't know about a thing called momentum.( guess you never been on a quad hah?), i swear it helps out . just don't be afraid to shoot the gas sometimes. ya in your nice 4-wheel drive you might be able to crawl up a hill . but i promise i will meet you at the top.
#22
#24
#27
Thats cool. Better tires will definately help and a bigger size will also but you will lose bottom end torque if you go to a bigger tire. Maybe if you go up 1 size you wont notice much but then again you only gain 1/2 inch of ground clearance. A lift kit really does nothing because you will not gain any clearance in the rear. Only tire size will gain the clearance. If you think you need more power then bigger tires will make it worse.
#29
#30
