Can a Warn 424 be mounted on the Rack (no drilling)
Old Feb 15, 2006 | 02:57 PM
robnhouston's Avatar
Default Can a Warn 424 be mounted on the Rack (no drilling)
I think the mounting bracket is only 2 1/4" bolts. hardly noticeable. Plus I would not remove mine when reselling. A few pics of my location below.
I would think mounted to a rack it would interfear with any loads up there. Actually under the rack is safer. But a ubolt and mounted under the rack should work out as mentioned.
Old Feb 16, 2006 | 12:23 AM
ForemanDan's Avatar
Also, if its hard to engage, something is wrong.
Old Feb 16, 2006 | 01:56 AM
GoodOleBoy's Avatar
Originally posted by: ddrumman2004
Thanks goodoleboy but where are you going to route the control cable in order to not put any sharp bends in the cable?
Im not really sure.So it work if i bring it through the stock hole where the rack is becuase of the bend? I do plan on mounting under the rack closest to the speedo if at all possible. Please excuse my lack of knowledge as I am new to the scene.
Thanks
95wolv
Sep 27, 2024 12:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
badgerboy1
Sep 26, 2017 06:11 PM
EIF
Apr 20, 2017 07:15 PM
