Carb problem 1985 Honda ATC 110-Help plz
Need help with a carb problem. I am fixing up the bike for my nephew. Fuel is coming out of the bottom of the carb when the gas is turned on and I don't know why. I'm not sure which hose is the overflow either. Anybody good with carbs?
Welcome to the forum Keith2006, your 110 carb has a stuck float or debris in the needle/seat where gas comes into the carb. If its a stuck float you may be able to fix it by tapping on the side of the float bowl with the handle of a screw driver. If its a dirty carb you wil have to take it apart and clean it.
110, 1985, 82, atc, brand, carb, carberator, carburator, carburetor, clean, diagram, float, honda, level, odyssey
