89 TRX350D Fuel Pump Problems
Old Feb 23, 2006 | 12:50 AM
heliman28's Avatar
Default 89 TRX350D Fuel Pump Problems
The problem I am having is that the atv sets for a month or so at a time and when I get ready to start it the carb is dry and the fuel pump will not turn on. I have read other posts and they talk about having to have spark first which it does. I can crank and crank and crank on it and the instant the pump turns on then it will start. I have tried taping on the pump while cranking and it makes no difference. The best way that I have found to get it started is turn the key on and crank for a short sec or two then just let it set with the key on for about 5 to 10 min then when I crank on it the pump normally starts running and if fires right up. Any suggestions on what causes this? Thanks in advance.
Old Feb 23, 2006 | 04:41 PM
quicksilver's Avatar
maybe it's a bad fuel pump relay? i never worked on one of those, but it's a good guess.
Old Feb 24, 2006 | 04:15 AM
ricweber's Avatar
I just bought a 1988 TRX 350D mainly to get parts for two different projects.
I should be getting the Service Manual that I ordered from the dealer in the next few days.
I'll look up your problem and let you know if I find a solution.
Ric
Nondem
Feb 22, 2020 12:20 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
