Rancher with some problems
Old Mar 29, 2006 | 12:48 PM
wideopenrider's Avatar
Default Rancher with some problems
I have a 2000 RancherES 2X4 in the shop. The customer said its stuck in reverse and when you hit the shift buttons it doesn't even try to shift and you can't shift it manually either. It has oil in the bottom of the air box too. Any ideas? Thanks
Old Mar 29, 2006 | 03:12 PM
mykool61679's Avatar
the reverse wire runs under the quad it may have came loose, this would cause it?
Old Mar 29, 2006 | 03:53 PM
You can't shift it manually either. With the emergency lever. And i think the cable is ok. I think i'm taking it too a dealer.
Old Mar 29, 2006 | 07:52 PM
cluby's Avatar
Ok sounds like the stub shifter may have broken off is side. ( the one that you use to manauly shift it)
you have to disasemble the motor to repair that, but I would take off the front cover first to check the linkage there, remeber these hade a update for shfit plates breaking then getting stuck in 5th.
Far as oil in the air box, cold weather starts and not warming up and just taking off with it and driving. And or custmer putting too much oil in it ( they cann't figure out that it is a dry sump motor and have to run it the check the oil.)
Old Mar 29, 2006 | 08:11 PM
Yeah, it was a farmers machine. So i'm sure they didnt' let it warm up or take care of it in any sort of way. I have yet to see a farmer who takes car of anything they own. No offense.
Old Mar 29, 2006 | 10:58 PM
quicksilver's Avatar
the oil in the airbox thing could have been the oil that dripped off the air filter.
Old Mar 30, 2006 | 03:22 AM
Gimpster's Avatar
Dry sump ?? On a 350 Rancher !?
So where is the sump ?
----- Gregg -----
Old Mar 30, 2006 | 10:12 AM
There was probably a good half quart of oil in the airbox so i dought it came off the air cleaner.
Old Mar 30, 2006 | 08:13 PM
cluby's Avatar
the dry sump is inside the motor on the left side (where you put the oil in it) They did that to keep the motor from being so tall, that's also why they don't have a over head cam set up on these.
Old Mar 31, 2006 | 02:35 AM
Gimpster's Avatar
Chuby -
Just so you know, I was not picking on you. Just trying to see if anyone actually realized why, the oil check proceedure. Many Owners don't know because there is no external tank, that this is a dry sump oil system.
Thanks man !
----- Gimpster -----
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
