rejetting?
It will depend on the quad and the pipe. With all pipe installations you will need to go bigger on the main jet. Sometimes you will need to come out a little on the air/fuel mixture screw and maybe even raise the needle jet. Again, it all depends.
You don't have to have a jet kit. I don't know much about a 250X but I've heard it was a lot like the 300EX. If it is then most likely it uses Keihin hex style main jets. You can pick them up almost anywhere.
Bm400ex
Jun 22, 2015 09:16 AM
