I think im gonna do it (350 4x4 es)
The Rancher 350 ES is a great ride. I love my 2005 and have no problems yet and I do ride it hard. My uncle has a 2002 ES and it runs great with no problems. The ES program has been around for quite a while and from what Ive read the problems on the 350 model are few and far between.
go go go! GO GET THAT ES man..
my es has had absolutly no problems.. except for that stupid cant rev above something to switch into and out of neutral..
thats just plain old safty reasons though
oh btw how do you seal the pull starter? what for?
is it just a gasket thing you put in there? really worth it? ill do it if i need to
if you ride mud and water, it is a must for the life of your motor. water seeps into the motor from the pullcord and the weep hole at the bottom of the pullstarter. this is a first class route for mud and water to get into your motor. the easiest way to do it is to take some RTV and pull about 6 inches of your pullstarter rope out and make a good bead. also seal the handle and where the handle sits on your pullstarter. and dont forget the weep hole at the bottom of the recoil.
hope this helps
hope this helps
