bough new Foreman, tons of questions...
Old May 29, 2006 | 12:29 AM
  #21
devocorky's Avatar
Default bough new Foreman, tons of questions...
just did the first oil change on the foreman...(6.5 hours)when i shined the light into the oil drip pan it looked a little metallic, like paint, so good idea to change the oil within the first few rides..
Old May 30, 2006 | 03:15 PM
  #22
JeffinTD's Avatar
I would guess that the metal flake paint looking stuff is probably assembly lube (as that's what the tube of stuff I use looks like) but it's still a good idea to do the first change a little early IMHO.
Old May 30, 2006 | 09:05 PM
  #23
rednck21's Avatar
mine also looked like it had a metallic tint to it. its a good thing i got that crap outta there!!
Old May 31, 2006 | 12:47 AM
  #24
devocorky's Avatar
How many hours/ miles on it when you changed it? I just came back from a ride and my change oil light came on @ 7 hours.( oil changed at 6.5)
Old May 31, 2006 | 07:58 PM
  #25
rednck21's Avatar
mina also had about 6.5 hours on it it when i changed it. the oil change light has to be reset somehow. i remember reading about it in the owners manual, but cant remember how to do it.
Old Jun 1, 2006 | 12:40 AM
  #26
JeffinTD's Avatar
Press and hold the Trip/ODO button and the Reset button at the same time.
Old Dec 31, 2006 | 09:04 AM
  #27
kingdiamond's Avatar
does anybody have a step by step for the valve adjustment on a 2005 trx500tm ? thanks
Old Dec 31, 2006 | 01:03 PM
  #28
mykool61679's Avatar
the specs are .006 i think, but if you bought a service manual it would tell you step by step, plus exactly what tools are neede and a time frame for how long it should take.
Old Dec 31, 2006 | 08:49 PM
  #29
JeffinTD's Avatar
In a nutshell, you remove the seat, side covers, fuel tank cover, fuel tank, and a little heat shield under the fuel tank. Make sure things are clean so no dirt will fall into the engine, and remove the caps on the valve cover, and remove the inspection plug on the side of the engine.
Looking through the inspection plug you will see the flywheel. Turn the engine with the pull rope until a T appears in the window. If there is slack in both valves, they are ready to adjust. If there is no slack, then the valves are in overlap at top dead center between exhaust and intake stroke, so you will need to turn it one revolution to get TDC between compression and power stroke. Valves should be adjusted with engine cold.
This is just a summary, and I'd also highly recommend getting the service manual.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
WilliamBos
Sep 22, 2015 04:07 PM
bmark0610
Sep 7, 2015 09:42 PM
