help! ME out with this situation!
Old Jun 27, 2006 | 10:39 PM
1988fast250x's Avatar
Default help! ME out with this situation!
ok i got the plastics all painted with the krylon plastic paint and evrerything like that but i can take my finger nail and scratch it off.....i am wondering will a clear coat prevent that from happening and also prevent chipping when i ride?? im dong woods riding and alittle MX so please help me out! or know of something that will help! thanks........
Old Jun 27, 2006 | 11:05 PM
Joshwfl's Avatar
I just used Krylon Fusion on my # plates on my CR500 and it doesn't scratch, I didn't use a clear coat either. I've done some heavy woods riding and crashed since, no scratches! It sounds like:
1. You didn't wait long enough between coats and it didn't cure properly
OR
2. You put too many coats on or the coats were too thick.
How did you prep it? I used an alcohol solvent and it worked great.
Old Jun 27, 2006 | 11:22 PM
like rubbing alchohol?? i think it did pack it on to soon are u supposed to lightly spread it on there with many coats??? i just sprayed it right on there hard which i dont think is good... and i was kinda humid! so i really dont know help me out thanks
Old Jun 27, 2006 | 11:23 PM
i just wet sanded it with 900 grit
Old Jun 27, 2006 | 11:28 PM
Joshwfl's Avatar
Yup, you got it on there too thick then and what's underneath didn't have a chance to dry.
Old Jun 27, 2006 | 11:33 PM
man that sucks what do u sugest to get it off??? thanks
Old Jun 27, 2006 | 11:49 PM
Joshwfl's Avatar
There's a product called ELO, Easy Lift Off that is supposed to remove paint from plastic, but I have used oven cleaner, starting fluid, and carb cleaner also. You could sand all the plastic, but it sounds like it's pretty thick and would just gum up the paper real quick.
Old Jun 27, 2006 | 11:53 PM
ok thanks alot i will probably try everything!! LOL
Old Jun 27, 2006 | 11:55 PM
Joshwfl's Avatar
Good luck, it's gonna be a lot of work.
Customer Service #1
May 15, 2020 08:46 AM
Pgbama11
Jan 16, 2016 08:19 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Pgbama11
Sep 10, 2015 08:20 AM
