05 250EX problem
Old Jul 8, 2006 | 09:10 AM
Blue600's Avatar
Default 05 250EX problem
I tried to start it and it would barely start with full choke and die. It is in the 90's here and didn't need the choke in that kind of temp to start it before. It won't stay running after it starts. I'm sure it's a carb problem so what am I looking for here? Any help is appreciated. I haven't had a carb apart in 20 years so I'm a little rusty.
Thanks for any help.
Old Jul 8, 2006 | 09:58 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Sounds like a plugged (idle) jet to me????
Old Jul 8, 2006 | 11:49 AM
hondabuster's Avatar
Its also called the pilot jet. And that was my first thought too.
If it will run at 1/4 throttle, but not idle, or if it will idle with the choke, but not with out the choke....id say for sure, its a plugged jet. Youll have to remove the pilot jet, and looking thru it like looking down a straw, you need to see light coming thru, the center hole. If you cant clean it out(the hole is about .012" diameter), then get a new jet...they are about 6 bucks from the dealer.
If youre gonna be leaving the 250 sit for more than a couple days, make sure you drain the float bowl, or run it dry....and the jet wont plug again.
Old Jul 9, 2006 | 08:27 AM
Blue600's Avatar
Thanks for the replies. It won't idle either.
Old Jul 9, 2006 | 12:20 PM
Either the idle speed is way too low, (doubtful), or the pilot jet is plugged.
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
cSchwartz
Jul 9, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
