2002 Honda Recon Blinking 1st gear
Old Jul 10, 2006 | 04:07 PM
Calkie's Avatar
Default 2002 Honda Recon Blinking 1st gear
I have a 2002 Honda Recon. Last year it was blinking 3 times, I replaced the angle sensor and it has been fine...until now. The 1st gear light is now blinking 5 times. I can manual shift. Anyone have an idea of what I need to check?
Old Jul 10, 2006 | 04:40 PM
quicksilver's Avatar
first, do the clutch adjustment. the motor has a hard time shifting gears if the clutch doesnt disengage all the way.
5 blinks is the ECU motor driver circuit. check continuity from the ECU to the motor on both wires. Jumper the motor manually with a battery, it should turn. if it doesnt, the motor is faulty. check the connections over for corrosion and make sure the terminals are tight. if all else looks good, replace the ECU.
bzdok1234
30
Feb 23, 2016 01:55 PM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
