how fast?
Old Aug 25, 2006 | 12:14 AM
WheelieRyder01's Avatar
Default how fast?
when my 01 400ex was stock and i was in sand my gps saind i was doing 70 as a top speed, also my buddy was right next to me on his machine also with a gps and we had the almost the same top speeds off by 1point sumthing miles an hour. no trees in the way either so reading has to be pretty accurate.
Old Sep 1, 2006 | 11:30 PM
Fulltiltrider's Avatar
Default how fast?
the problem with this is a raptor is so starved for air that you will never get it to 8500 rpm with a stock pipe its hard to hit the rev limiter in 2nd gear let alone 5th. the raptors rev limit is 8500 rpm but if you look at a stock dyno run for it its only putting out around 11hp at that rpm were if you put a ct pipe on it its producing 44hp at 8500rpm remember a pipe dosent change a bikes top speed,just how fast it gets there
Old Sep 1, 2006 | 11:37 PM
woodsracertofast's Avatar
Default how fast?
i dont think a 450r will do 90 with just a hrc kit, and a pipe.no way
Old Sep 1, 2006 | 11:39 PM
4wheelerfred's Avatar
Default how fast?
[img]i/expressions/face-icon-small-confused.gif[/img]!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 2, 2006 | 12:20 AM
  #15
Default how fast?
I dont think so either, unless there are gearing changes you cannot go any faster than your gears can take you, dosent matter if you have a 100HP
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Irishman301
Sep 23, 2015 01:47 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
