Wiring Diagram
Old 11-24-2007 | 08:02 PM
svaviator's Avatar
Default Wiring Diagram
Pro Rider - I know this is probably at least the 100th request, but can you please send me the wiring diagram for a 1986 Honda TRX350 also. svaviator@yahoo.com
Thx man.
  #52
Old 11-24-2007 | 10:12 PM
HondaMechanic's Avatar
I emailed it to you..
  #53
Old 12-15-2007 | 07:49 AM
jayjayfishin's Avatar
Hey Honda Mechanic - Just wanted to let you know the prints you emailed me awhile back really helped me out!! Thanks a bunch!
  #54
Old 12-31-2007 | 01:38 PM
ATV Freak's Avatar
Your diagram is not clear
  #55
Old 01-21-2008 | 07:39 PM
mrl21's Avatar
HondaMechanic,
I got stupid and disconnected electrical connectors and vacuum lines to hand clean my 2001 TRX350ET Honda Rancher ES. Problem is, I can't remember proper electrical connections or remember where vacuum hoses reconnect. Do you have diagrams to help? Anything would be greatly appreciated...
  #56
Old 01-22-2008 | 08:55 PM
mrl21's Avatar
Thank you very much HondaMechanic.....your help is a great value.......I hope everyone appreciates your valuable help as much as I do.
  #57
Old 01-23-2008 | 09:34 PM
dwing's Avatar
I've run into the same sort of trouble. We have 86' TRX350. Ran fine until I parked it, now it doesn't run at all. Pretty sure it's in the wiring, but can't find a manual or a diagram anywhere. Any help would be appreciated.
  #58
Old 01-24-2008 | 07:06 AM
PM your email address ...
  #59
Old 01-28-2008 | 09:56 AM
deetzman's Avatar
I Have a 2000 rancher 350es. this weekend i installed a winch on it and the wiring from the switch needed 12v from key switch. After i completed installation i turned the key on and winched worked fine. then i started atv and went to raise the snow plow and the atv quit and will not start now.. I need some advice and a wiring diagram ... thanks
  #60
Old 02-16-2008 | 12:17 PM
cellboothmgr's Avatar
i was wondering if you could send me the wiring diagram for a 1994 300ex. i re wired just about everything on the quad, i pressed the starter and the spark plug coil made a hissing/crackling sound and then POOF, up in smoke. im assuming i have some wires crossed somewhere along the line since the starter wont crank anymore.
Thanks
Quick Reply: Wiring Diagram
