450er 06 maintenance
Change the oil often! Change it after the first hour (along with the filter), and I would suggest you not ever go more than 5 hrs max without an oil change.
There are a couple of oil threads on the board right now, so I would suggest you check them out. After break-in, run a synthetic oil. Run at least 100 cc's of extra oil in the trans.
http://forums.atvconnection.com/mess...did/503080.cfm
http://forums.atvconnection.com/mess...did/502653.cfm
I dont even go by hours ,I go by color. the oil level window shows it all ,when the oil just starts to get alittle dark i change it and that seems to be after about 2 to 3,, 6 hr rides and i change the oil filter every other time i change the oil ,,,,honda hp4 without molly 10w 40 as far as the trans i use exactly .95 of a quart it gets changed every other time the engine oil gets changed hp trans oil honda, iv got about 50 total hours on my atv i install the hrc kit the day i got the bike ,,i checked the valve clearance at about 30 hr and it was still right on were its was supposed to be .
Totally worn out oil could look absolutely clean, so I sure wouldn't rely on how "dirty" my oil looked to determine when I did an oil changed. I think the general consensus is that on this engine, 12-18 hours is to long to go without a change!
Iv never seen totaly worn out oil looking clean ,so id liked to no what kind of oil your talking about ,oil gets dark from polishing and wear ..of the internal workings. oil doesnt stay looking clean it get darker as you ride, any oil, general speaking its still works out the same by the time i get 12-16 hrs on it the oil is slightly dark and it gets changed any sugestions on this oil your talking about ?
yea the time range you are talking about is about within recon's time range so its the same thing anyhow just maintain the quad oil wise changing the engine oil often and checking the level every ride and also check the tranny oil...when the bike is cold let it sit for a few minutes idling and then shut it off and check the oil level and on the other side there is an tranny oil check plug and if you see oil come out then you are fine and if you don't see any apply slowly until you do...also just keep the airfilter cleaned and chain lubed up and clean...finally get the valves check or adjusted about every 10 to 15 tanks of gas.
I would certainly change my oil any time it looked dirty, no matter how few hours it had on it. (Actually though, modern oils can absorb quite a bit of dirt, without seriously effecting their lubricating ability.) The problem with your post, is it might encourage some uninformed reader to pass up a needed oil change just because the oil doesn't "look dirty" yet.........at least that's the way it sounded to me.
Those who want to play it safe with this high strung engine, will be wise to keep the oil change interval fairly short. While I try to keep my oil changes at no more than 5 hours (that would be one average desert day ride), there are times we do weekend camping trips where I might have to excede that, because I sure don't want to be doing an oil change out in the dirt and sand at some place like Ocotillo Wells! But, even on a long weekend trip, I find I don't spend all my time on just the 450 anyway. There are always lots of different quads, bikes, Rhinos, rails and Jeeps to rip around in, so it keeps my 450 mileage down to something reasonable.
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
