TRX 350 front knuckle
Old Nov 19, 2006 | 08:21 AM
chrisfaux's Avatar
Default TRX 350 front hub
I am trying to replace the bearings in my front left knuckle. I have loosened the upper and lower bolts but I do not seem to be able to remove them. There is no more thread left to unscrew. Is the something I have missed? They are loose but when you look closely there is a lip on the bolt between the knuckle and the drive that stops it being removed. How do I get these out?
Can anyone tell me how the front knuckle should come off in order to replace the bearing?
Many thanks
Chris
Old Nov 20, 2006 | 07:28 AM
HondaMechanic's Avatar
Default TRX 350 front knuckle
The ball joint is a taper fit ... We just hit the knuckle next to the hole and they will pop right out ..
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
